z3 1.9 shifter in 1991 318is
  • immajackuup
    • Dec 2010
    • 1132
    Will the z3 1.9 shifter plug and play without any modification??
  • gearheadE30
    • Jun 2007
    • 3734
    Yep, it should.
    Project M42 Turbo
    • immajackuup
      • Dec 2010
      • 1132
      Originally posted by gearheadE30
      Yep, it should.
      are you positive?? no need to bend selector shaft?
      • DRTSRFR
        • May 2008
        • 1836
        Got a balancer on the driveshaft?
        Suspension tips here...
        http://www.r3vlimited.com/board/album.php?albumid=757
        • trackjunkie21
          • Jan 2010
          • 3962
          Yes, no need for any modification.
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • immajackuup
            • Dec 2010
            • 1132
            I think so,everything is stock.
            • gearheadE30
              • Jun 2007
              • 3734
              I had a 1.9 lever on my car for awhile and didn't need to modify anything, so I'm sure to that extent. Certain cars got a balancer around the guibo that my car doesn't have. Check your car to make sure.
              Project M42 Turbo
              • jrobie79
                • Mar 2006
                • 2526
                no modification needed, it might sit a little up and to the right in the opening (shifter itself, not selector) but its so minimal you wont even notice it
                1991 318i ---- 308K - retired
                • immajackuup
                  • Dec 2010
                  • 1132
                  i c,what year is your car? As why I ask because some people told me 90-91 318is doesn't need to bend selector shaft comparing to lower model IS.
                  how you like the z3 1.9 shifter?
                    • 37832
                    I've never bent the selector shaft in ANY E30 I have installed a short shifter in. Just an FYI from somebody who has done more than read about it on the internet.
                    The Z3 1.9 will fit with no issue. :)
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • immajackuup
                      • Dec 2010
                      • 1132
                      kool,guess i buy the kit from bma for 100. any tips when installing?
                      • jrobie79
                        • Mar 2006
                        • 2526
                        get the delrin carrier bushings, might as well use something solid while its all apart....that rubber one will eventually wear out
                        i believe turner sells them, they are a UUC product
                        • immajackuup
                          • Dec 2010
                          • 1132
                          i assume this is it
                          http://www.turnermotorsport.com/html...PRODUCT_ID=DBR
                          • StereoInstaller1
                            GAS
                            • 22679
                            That lever will sit a little father forward (same as I have in mine) but I prefer that, as I have long arms.
                            Closing SOON!
                            Thanks for 10 years of fun!
                            • immajackuup
                              • Dec 2010
                              • 1132
                              damn,what other shifter you recommend for people with short arms?
