Been rearching through multiple forums and looking through the bent. manual for the proper timing on my 85 318i. on this sticker i found stuck on the pass. side of the car. saids 26 degrees BDTC At 4000 _+ 50 in neutral. im not sure what that means exactly. every where i've looked so far only saids top dead center TDC. whats the "B" for?
as for idle timing not required. there seems to be plenty of people with idle issues including me. is it because we adjust the idle thought IDV and dizzy?
so if someone can kindly explain what the ignition timing means...that will be great.
thanks all.
Eric
thanks all.
Eric
