Having this weird engine cut off issue. I will be driving and then the engine will cut off randomly and if I mash the gas I can keep it alive. When this happens the CEL comes on briefly. This will happen through all of the revs. I have replaced the Main Relay, CPS(3k miles ago) and fuel relay . The only code it is giving me is 1223 (coolant sensor) but i dont understand how that could be causing the car to do that. I looked for any vacuum leaks and found nothing.
Also the fuel pump is a bit loud but it does not seem like its doing anything weird.
Any ideas ?
Any ideas ?
