I have a 90 325i and it has an overheating problem that i can not figure out. I replaced the water pump, thermo and radiator already. The clutch fan seems to be ok but the car seems to be overheating to quikly for that to be the problem.
So here is what happened one day when I was checking my fluids I forgot to put the resevoir cap back on. I drove the car for a little while and when i noticed the car getting hopt i stopped saw the cap and put it back on. The tank had not run dry yet but since then it overheats all the time. I tried replcaing all the above parts and bleeding the system all to no avail. The car will sit at idle and not overheat to quikly might take 15 minutes but as soon as you start to drive or rev the engine the temp goes right to the red within a couple of minutes even when driving. Also it seems when the car is idling that water is not flowing through the hoses. And I am not getting hot hot air ever from the vents with the heater on high.
Thanks for any help.
mike
mike
