Bryson says there's a Conforti chip for an M52 with M3 cams. Its not on the TMS site, and he hasn't been able to point me to a link for it yet. Anyone want to prove it exists? I'll be needing one in the next several weeks.
Conforti (TMS) chip question
Re: Conforti (TMS) chip question
There would be no "chip" for M52. OBD-II = shark injector.Originally posted by permitBryson says there's a Conforti chip for an M52 with M3 cams. Its not on the TMS site, and he hasn't been able to point me to a link for it yet. Anyone want to prove it exists? I'll be needing one in the next several weeks.
M50 = http://www.turnermotorsport.com/html...UCT_ID=413-252
There is no shark injector for M52 and M3 cams.E36 325, E34 525 TMS Peformance Chip, 2.5 with M3 Cams
Part #: 413-252
Applications: 1993 - 1995 325i, 525i (E36, E34)
TMS Performance Chip for E36 325i and M3 Camshafts
If you've installed M3 cams in your 325i but have not gotten this Performance Chip then you're missing out on half of the horsepower. This Performance Chip is tuned to take full advantage of using these cams on the 325i. You can expect huge gains in the top end of the RPM band but thanks to this chip's dyno tuning there is no loss of low-mid range torque. You get seamless power delivery from low RPM all the way up to the 7000 RPM rev limit. Jim Conforti achieved this by altering the fuel and spark maps along with the cam timing to take full advantage of premium 91+ octane fuel. The rev limit is raised and the top speed limiter is removed.
Price: $349.95
To convert to OBD-I, wouldn't you run a M50 chip, then be able to use ^ chip. -
Premit what are the plans for your car? Are you swapping motors? Maybe that will help people point you in a better direction.91 m3Comment
I've been pointed in the right direction now as to what chip I need.Originally posted by 325ProjectzPremit what are the plans for your car? Are you swapping motors? Maybe that will help people point you in a better direction.
I'm going OBD1 M52 with S52 cams, UUC underdrive pulleys, TMS chip. I'm taking some parts off the M50 for the M52, but the remainders will go to Bryson in exchange for installation and building.Comment
