cluster gas gauge b/w early and late models
  • 87-325ic
    • Apr 2006
    • 1198
    besides the fact that the sending units are different, why is the gas needle reading 1/2 tank vs the 1/8 tank i actually have.
    i have an early model, but the cluster is from a newer model, (single pump)
    Is is as simple as replacing the gauge from the back of the cluster? or is it hardwired in the cluster circuit boards?
  • 87-325ic
    • Apr 2006
    • 1198
    yes. it is as simple as that. i answered my own quesstion by doing it
    Now, why isnt my tachometer working? is there a difference in the tachs b/w early and late model?
    • 87-325ic
      • Apr 2006
      • 1198
      sweet!!
      apparently the SI board helps run the Tach... lame.
      swapped boards and now my tach works
      i finally have a speedometer and tachometer!
