Rear Bearing Question
    Ok so I have a 1988 325is and I need to take the rear bearing nut off. Will I have to do anything to the lock nut. Like maybe bend it away from the nut. I have a 30 mm socket that barely fits on the nut, so I'm assuming the lock nut washer needs to be dealt with. LMK guy's and thanks for your expertise. Only reply if you have done this before..
    Thanks
    Barry
    Screw driver+hammer will take care of that lock washer.
    Originally posted by Gruelius
      You don't need to do anything with the lock ring to get the nut off. You will need new lock rings to reassemble and it is a good idea to use new nuts. There isn't much depth to the nut, so I use a 30mm socket that has had it's bevel ground off squarely.
        Thanks Guy,s just as I thought
        Barry
          Do you need to rent the tool?
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          Instagram.com/garageaholic
          Youtube.com/garageaholic
