88-325i 4door. WHY DOES this happen? OE radio and speaker arrangement. short somewhere?
Retractable antennae
Do you have an aftermarket stereo or the factory one?
"See, we're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anyone wanna see second prize? Second prize is a set of steak knives. Third prize is you're fired."Comment
Make sure the wire that plugs into the "PA" prong on the back of your radio is still there and not broken, for starters.
The antenna motor is only supposed to get power long enough to raise the antenna. Power to it is then shut off so the motor isn't constantly pushing against something that isn't moving. If you're looking for a power source for something like an amp to turn it on when the radio is on (or for any other reason) the antenna motor power is not a good place.
SteveTomahawk -
When you care enough to send the very best.Comment
