mustang injector question
    ok i have a stock 325i 2.5L auto.
    i found a guy selling his '93 mustang injectors for CHEAP.
    do these just take place of factory injectors or is there modification that needs to be done? also would i NEED to buy the MarkD chip?
    thanks.
    I am curious of this as well as I have a 5.0L mustang with the engine out right now getting rebuilt.
    Only difference is I have a 325e 2.7l man
    not to thread jack man! curious
      hey if you got the same question join the party!
      btw these are 19lb injectors i am looking at.
        yeah those are the stock injectors, im buying 23 lb injectors for my fox when the engines complete
        How much you find those injectors for?
          havent made an offer yet, want to know if i need to buy the MarkD chip first.
            gotcha
              A stock m20 does not need that much fuel. I would put m50 injectors instead. They are 17.5ib. which is more than enough fuel for an m20. Honestly, I would recommend another chip. The Mark D chips suck.
              1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
              Visit www.BimmerHeads.com for all of your 12 valve needs!
                The eta engine uses low impedance injectors, Mustang injectors are not compatible.
                I agree with you on not needing 19lb injectors on an otherwise stock engine but what's wrong with the MarkD? I have never heard a bad thing about it from anyone, myself included when I had an m20.
                '89 Alpine S52 with goodies
                  The Mark D chip has a bad idle and it also has trouble starting. I'm running a e/i hybrid m20 with a nicely worked head and a nice cam with the m50 inj. and a $30 ebay chip. Honestly, the ebay chip is way better!
                    Is the chip specifically tuned for a cammed m20 stroker with head work and 17.5lb injectors?
                      The Ebay one? no
                        I meant the MarkD. I'm just surprised you had a bad experience with it.
                          We used two different mark d chips in four or more e30s and they all had the same problems. everyone says these chips are the shit but I wouldn't run this chip if it was free.
                          .02
                            .02
                            so you're saying just go get the 17.5 injectors and a ebay performance chip?
                            i like that idea, well my wallet does atleast!
                              There's no advantage to eny upgrade of injectors on a mostly stock M20B25 engine. The stock injectors have sufficient head room to achieve 12.5:1 (which is richer than you want to be) across the entire operating range if the rest of the fule system is working like it is supposed to. A race car would see 12.8-13:1 and that is easy to reach with a WAR chip or similar. A mostly street car is better served by about 13.5:1.
