couple engine related questions
  • NC325iC
    • Mar 2004
    • 6565
    hey all
    ive been working on swapping out my old m20 for a stroked one
    i have a few questions though
    -what bolts need to be replaced every use? ie do i need to replace flywheel bolts or tranny to engine bolts etc...
    -my m20 has a single mass flywheel and therefore a springcentered clutch, the stroked m20 has a dual mass and a solid center clutch, would i get any benefit from the solid centered clutch, would it work?
    i think thatll do it for now, any help would be great thanks alot.
  • hamann318is
    • 3382
    Re: couple engine related questions
    Originally posted by NC325iC
    hey all
    Keep the single mass flywheel. The springs on the clutch keep the abuse on the drivetrain down. The light weight is the obvious benefit in that situation.
    The BMW 318 is back. With a vengeance.
    • rs4pro3
      • 5808
      the flywheel, and pressure plate bolts should be replaced, as long with the nuts that hold the driveshaft and tranny to the guibo and connect the driveshaft to the diff.
      85 325e 2.7 ITB'd stroker
      • NC325iC
        • Mar 2004
        • 6565
        thanks alot guys, so the bolts that hold the tranny to the engine are good for another go?
        • e30Matt
          • 5077
          Yes, they should be fine.
          • NC325iC
            • Mar 2004
            • 6565
            k love the sig btw hilarious
            • NC325iC
              • Mar 2004
              • 6565
              so general concensis (cant spell) is that i should use the single mass(duh i was gonna anyway) and the springed clutch.
              that would basically be my old setup
              and unless it was something else down the line i believe that it has been slipping at high rpms, could that be caused by my rear main seal which i believe was leaking oil
              • NC325iC
                • Mar 2004
                • 6565
                bizzump
                • arnoldgtr
                  • Mar 2004
                  • 153
                  Clutch slip is most likely at maximum torque, not at the highest RPM's.
                  If you still suspect the clutch has been slipping, you should be able to tell by inspecting the disc. It will be glazed.
                  The single mass flywheel surface is raised about 1mm where the disc contacts it.
                  If the flywheel is machined, you MUST have the step remachined in it. Otherwise, the clamping pressure won't be enough.
                  John
                  88 ///M3 Cinnabar
                  84 318i Black
                  • erik325i
                    • Jan 2005
                    • 3567
                    All of the self locking nuts need to be replaced (driveshaft bolts, exhaust manifold bolts, and any other self locking nuts). I have read that you should replace the flywheel bolts, but I don't see why. I even asked the owner of my local BMW performance shop, and he told me that there is no need to, as long as they are in good condition and use some loctite. The torx bolts that bolt the tranny to the enging should be fine.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      dont understand that last part, i havent had any work done to the flywheel ever i dont think
                      • kowalski
                        • Jan 2005
                        • 1791
                        every time you seperate the fly wheel your supposed to have it check and if necisary machined.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          well shit oh well
