Alright this car is wearing me thin. Hopefully one of you guys can help me out i need to know which wire plugs into what injector. I bought the car with the top stripped down, so i went and checked the head and got it cleaned and then started changing out all the wearable parts. Well now i am to the injectors and the little yellow tape is gone off of 5 of them so i know what plug goes to cylinder 5 otherwise im at a loss. I have the bently and i did not see anywhere in there a list for what goes to what. I also searched and searched and didn't find anything about the wiring though a lot of you have changed the injectors hopefully there is a way to tell. Thank you all in advance.
e30 Fuel Injector Wiring Help
I had to do almost the same thing. Check the wire colors in the ETM.
At least for an '87 is, injectors 1/3/5 have a brown/white wire and 2/4/6 have a Brown/Yellow wire (the other wire should be Red/white for all 6)
To add something useful to this, once you figure out which injectors are which, Take a paint pen or colored zip-tie (very small one) or something similar and mark each of the connectors on one of the banks (injector 1, 3 and 5). That way, you have a very quick visual next time you have to unplug the injectors.Ben
Thelma-Louise, the '88is Chump Car - back to M20 power!
2014 ChumpCar Season Schedule!
April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
May23-25 Watkins Glen, NY: 4th, 5th, 4th
October 4 PittRace Sprints: 2nd in C-class
October 18-19 NCM, Bowling Green KY: 2nd, 1st!
Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
Find us on FB! Schaut Speed Motorsports -
From what I've gathered on the forums here and in the books, all of the M20s are batch fire, so each bank (1/3/5 and 2/4/6) squirt fuel all at the same time.
So yes, actual location doesn't matter, just even/odd. Although, wire length pretty much forces which connector goes onto each injector. Wire length for 3 and 4 are MUCH shorter than 1 and 6.Ben
Find us on FB! Schaut Speed MotorsportsComment
