Key broken off in door lock
  • hotghias
    • Jan 2004
    • 148
    I've got a key broken off in my driver's door lock. It's not hanging out the edge - can't grab it from the outside. Any ideas?
    Thanks.
  • b*saint
    • 3794
    R & r.
    Ma che cazzo state dicendo? :|
    • rammstein
      • Jul 2009
      • 367
      There are more than likely some smarter guys on here than me, but here's what my feeble mind can come up with:
      1. A piece of duct tape, twisted into a very fine point, carefully inserted into lock in the hopes of sticking it to the key and removing?
      2. Really strong magnet?
      3. Suck on lock with your mouth, and see if it comes out? Maybe get chick to help with this?
      4. dab of super glue on a toothpick, inserted and hopefully glued onto key stub to pull it out? (Don't do it on second thought, you'll end up gluing your lock or something)
      5. Pull off driver door panel, remove vapor barrier and see if you can't somehow pock it out from behind?
      6. Worse case, remove the lock completely to either repair or replace.
      The smart guys would probably just skip to step 6, but I prefer the hard way sometimes :D
      E30 M52B28
