2 vacuum lines / M42
  • hamann318is
    • 3382
    Can anyone tell me where the vacuum line right under the TB goes and the vacuum line to the left of it goes looking at the lines from the driver's side?
    The BMW 318 is back. With a vengeance.
  • kowalski
    • Jan 2005
    • 1791
    that one under the trottle body goes to your valve cover i believe and im not sure what you mean by the one to the left of it, are you talking about mostly because im too lazy to go and check outside.
    • hamann318is
      • 3382
      I'm talking about the one that come off the of TB from the bottom. There is one that's to the left of that one aswell.
      • nickmp0wer
        • 1427
        lets see, there on one that goes to the valve cover, one that goes to the rubber intake boot, theres one that goes to the ICV, and theres a small one the goes to the fuel pressure regulator thing. I can think of anymore right now
        • nickmp0wer
          • 1427
          if its the plate that goes between the tb and intake manifold those are coolant lines
          • hamann318is
            • 3382
            I have all of those. I'm talking about the line comming off of the bottom of the TB, under the coolant piping.
            • nickmp0wer
              • 1427
              it doesnt go between on the rubber boot between the tb and afm? does it just go to one of those hoses on the strand of hoses? i will go adn try to look now. Also i figured out after many hours of stressing and aksing on message boards theres i diagram of the hoses in printed somewhere in the engine bay
              • nickmp0wer
                • 1427
                yeah i think it comes off the tb at like a 45 degree angle then theres a 90 degree fitting and it goes to the cluster of hoses. If your standing on the drivers side you should see a little metal pipe the goes in the shape of a U into the cluster of hoses. The hose from the tb attaches to the left side right above it/into it
                • hamann318is
                  • 3382
                  Thank you!
                  I had guess that, as that hose has a 90 degree that seemed like it'd goto to the 45 piece.
                  • nickmp0wer
                    • 1427
                    hey do you know how tall the lower part of the intake manifilold is where it attaches to the engine?`Im gunna be buying a flat peice of metel to go there for me to weld some pipes to but i dont know how big it is. You probably dont know but but id thought id ask
