m30 afm swap
  • NC325iC
    • Mar 2004
    • 6565
    m30 afm swap
    the inner side of the plugs is different so i cant put the m20 plug in the m30 afm wtf do i do?
  • NC325iC
    • Mar 2004
    • 6565
    damnit someone has to know
    • rs4pro3
      • 5808
      Every single M30 AFM I've had the E30 plug, plugs right in and I've had at least 10 different ones in my possesion. You sure it's an M30 AFM?
      85 325e 2.7 ITB'd stroker
      • NC325iC
        • Mar 2004
        • 6565
        well shit i hope so
        it looks like one looks to be same size etc has a different plug though
        bought it off bkelsey
        maybe thats why he sold it
        edit:its from a 733i so i assume its an m30
        • NC325iC
          • Mar 2004
          • 6565
          anyone?
          • rs4pro3
            • 5808
            What year 733? As the early M30 AFM(pre 82) are the same size as the m20 units. What is the part number on the black cover? You can swap the plugs easily enough if needed.
            • bkelsey86
              • 1173
              hmm I was unaware of there being a different plug, I've never seen one with a different plug and I know for sure it's an m30 afm. I acquire random parts that I don't need, thats why I sold it.
                • 37828
                I have the 027 which I am pretty sure is off a 7, plugged right in and worked, no internal swaps needed
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • NC325iC
                  • Mar 2004
                  • 6565
                  this is an 011 i think
                  edit, and the plugs cant be swapped easily the size of the hole where the plug goes into the afm itself is a different shape for each
                  the m30 has 6 prongs i believe and the m20 has 4
                  • Erick
                    Official R3V Drifter
                    • 11169
                    I swapped internals.... mine wasnt a 027.... I have no issues.... throttle response was amazing.
                    ..::Support FullOpp::..
                    FullOpp Stickers for sale!
                    Feedback Thread
                    • NC325iC
                      • Mar 2004
                      • 6565
                      problem solved
                      luckily my new engine came with an afm as well
                      turns out the afm from my car was the odd part
                      normally the hole that the back of the plug goes in is rectangular but on mine it was an octogon so i used the plug from the other m20 afm i have
                      weirdness
                      on another note
                      how can i run the fuel pump, no battery or wiring harness in the car just need to run fuel pump to drain the tank
                      • rs4pro3
                        • 5808
                        Hook a battery up directly to the pump, it's only 2 wires one ground and one power.
                        • arsevader
                          • May 2005
                          • 1025
                          And stand back and wait for the vapours to ignite from loose live connections. ;)
                          If you want to drain the tank, use the drain plugs in the bottom and avoid killing yourself.
                          James
                          • rs4pro3
                            • 5808
                            Ya, ya He asked so I told him. Make sure to smoke a cigarete while youre at it also 8)
                            The drain plug is in front of the passenger rear wheel, let it soak in PB baster for a while then very carefully remove it.
                            • NC325iC
                              • Mar 2004
                              • 6565
                              the pump method was too easy, and anyway the battery wasnt in the car i had it on the ground near the back seat and the fuel came out up front, no harm done
