changing obc bulbs
  • ///M42 sport
    • 3952
    changing obc bulbs
    how do I get the obc out in the first place? :(
  • bimmer8604
    • 3017
    dig in.
    You have to remove the shifter and ebrake surrounds, then you gotta pull out your center consol a bit to undo some screws. its really not that bad, just keep track of where everything attaches and what screws go where.
    then theres a little tray thingy that the lights are on in the OBC, its not that difficult, just a bit time consuming.
    HTH
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
    • Tangent
      • Mar 2004
      • 476
      I didn't have to remove the shifter or any part of the lower console when I did that job...
      • BMW BMXER
        • 2325
        Me either.
        Sold it.
        • bimmer8604
          • 3017
          eh, mybad, we removed it just because we were doing some other work back there, i guess you wouldnt need to remove it(not like its very hard anyways)
          Kyle
          DILLIGAF
          • ///M42 sport
            • 3952
            are there any screw attaching the obc? the air knobs are really dim. How can I get back there to change those bulbs?
            • Zoso
              • Apr 2004
              • 85
              The OBC is held onto the center cluster face plate. You don't need to unscrew the OBC from the cluster plate to change the OBC bulbs.
              Go to my website - linked in my signature. I have writeups on retrofitting the OBC and replacing all the dash/cluster bulbs. You should be able to figure out what to do from those writeup.
              One thing to note - since you are not retrofitting the OBC, you don't need to completely remove the center cluster face plate... but if you want to replace all the bulbs behind that plate, just take it out and then get easy access to all the bulbs. You don't absolutely need to take the plate off, but it is easier than fishing around back there and hoping to grab the bulb.
              E36 1998 M3 Coupe - Titanium Silver (M3 Tech Procedures)
              E30 1991 318i - Red (318i Tech Procedures)
              • ///M42 sport
                • 3952
                thanks for the writeup zozo. I got the faceplate out. How many bulbs supply the lower half of the face plate?
                Also are the bulbs that supply the vent knobs replaceable? Those little cylinder copper things in your picture.
                • Zoso
                  • Apr 2004
                  • 85
                  There are 2 bulbs behind the center console area. They are listed on this picture and are much easier to get to if you take the consolve out.
                  As far as the vent sliders - there are no bulbs in there. If you replace both bulbs in the center console area, everything should light up just fine assuming your plastic light diffusers aren't broken. (which I doubt).
                  • ///M42 sport
                    • 3952
                    thanks I figured out where the knob lights come from.
                    • armeN
                      • May 2005
                      • 327
                      WTF! did you do?
                      I go wuaaaaaahh pssssshhhhh!!!!
