It should be clipped on above the ABS computer on the left side of the steering wheel behind the knee bolster. You won't have to pull the gauge cluster to get to it.
pull the lower cover under the steering wheel.
you'll see the ABS computer. clipped to the bracket should be a relay, that's the overvoltage relay that blows up
no idea what this "rubber flap" is you're referring to.
alright i have seen that relay, the one that i got from world pac has round connectors and i couldnt find any relay on my car with round connectors, looks like i need to kick some ass! haha, thanks.
you can repair your relay if you have some electrical know-how. the metal cover on the relay can be pulled off and the fusible link replaced with one from a similarly rated regular fuse. search around, i've seen posts on this in the past
