Anti-Lock?
    Anti-Lock?
    I left my lights on and had to jump my car this morning. After I did everything seemed to be fine except the "Anti-Lock" light on my cluster is on. How can I fix this besides pulling out the bulb?
    The relay thingy under the black cover on the ABS computer thing. Torque screw for the black cover. Possible way to get rid of it, other ways I'm sure.
      Same thing happened to me after I connected one of those self-charged battery jumper contraptions to my car with the key in the on position. You have to get under the dash to find the abs over-voltage relay. It should be clipped on above the ABS computer on the left side of the steering wheel behind the knee bolster.
      Pull the relay apart and look at it. There should be a fuse-like wire that's blown. Take the fuse part out of an 8 amp fuse and solder it in there. Put it all back together and the light should be out.
      If you must, you can get a new relay for like $25 from Autohaus AZ. P/N from ETK 34 52 0 005 192. When I did the search on Autohaus AZ it came back and said it was replaced by p/n 34 52 1 154 894.
      Good luck.
      Steve
      Tomahawk -
      When you care enough to send the very best.
