NEW rear wheel bearing Wobbly.... help plz
  • etxxz
    • Feb 2006
    • 2085
    I had to replace my RR bearing. It went so smoothly i couldn't believe it. Within 1hr i had it out. Now i have the new one in and my hub wobbles, like the middle from inside the outer race. Am i missing something? Will it tighten up when i bolt up the axle or what?
    I used super gynormous C-clamp and an Autozone wheel bearing install kit (disks that push on the outer bearing) to install it. I froze it beforehand in my house freezer to shrink it. Greased it, slid right in barely popping 2-3 times along the way.
    New Clip. Used the same C-clamp to push the hub in, now it wobbles if i shake it. I'm out of words. I also took the brand new uninstalled one out of the freezer, intended for the driver's side, installed the other hub (by hand only a few mm in) on it and it also wobbles.
    Both the outer race and inner race fit tight... this c-clamp has been my version of a hydraulic press for many years... plus it cost like $100.
    What am i missing guys??
    Car Specs:
    e30 with 318Ti 5lug rear end.
    Used bearing 33-41-1-124-358-M34
    Brand: FAG (...no offence to anyone)
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
  • AndrewBird
    The Mad Scientist
    • 11896
    Put the axle in and see if it tightens up. I bet it will.
    • etxxz
      • Feb 2006
      • 2085
      lol rookie mistake. it sure did..... the front of the axle (@spline/hub) and the back of the huh squish the bearing together -.-
      I thought id proceed and take the axle back out i needed be... everything is so clean and greased up that it installed like butter... that and i rented like $300 worth of tools so i have all the "muscle" i need.
      Thanks though. Doing the other side now..
      91 BMW 325i [sold]
