You can pull each sensor, drain it of gas and check it's resistance when the sensor is right side up (empty tank) and upside down (full tank). The full tank resistance should be zero and the empty tank resistance should be about 60 ohms.
That sounds like a bad left (driver's side) sensor. But it could be a weak fuel pump or a clogged filter that is reducing the system fuel flow rate to the point that the siphon isn't working well. That would leave more fuel in the left side of the tank than should be there. The flow rate test is in the Bentley manual.
The problem I face right now is that when my gas neeedle is on the red mark, I know the tank still has 6 gallons left (because filling up at the gas station stops at 10 gallons) despite the indicator suggesting I have a lot less. However, it has no trouble recognizing when the tank is full. I suspect one of the sensors are faulty but am confused as to which one it owuld be.
