exhaust mani won't sex with the head
  • lolcantturn
    • 4588
    My exhaust manifold simply will not bolt on all the way after getting a new head. Like it's not that the gasket is leaking, I just can't, even after breaking some studs and replacing with bolts, get it to sit flush against the head. Any tips?
    Originally posted by TSI
    OEM+
    Are the exhaust manifolds disconnected from the down pipe? If they are it should be trivial to attach the manifolds to the head. If they aren't, the exhaust may have shifted when you pulled the head. The fix for that will be to remove the exhaust and put everything back together starting at the head.
    • Pussy30
      • Feb 2011
      • 463
      yeah either this or did you check that the gasket is lined up?
      • YeOldeBuggy
        • 208
        You're exhaust manifold flange could be warped?
        Thad.
        Need BMW parts?
        http://www.blunttech.com
        or face ultimate peril.
        • lolcantturn
          • 4588
          Got it. There was a really thin awkward small piece of exhaust gasket on the stud that i didn't catch before...such a dumb mistake.
          OEM+
          • LJ851
            • 7919
            Yeah thats pretty dumb but look on the bright side, you prob wont do that again.At least right away.
            Lorin
            The M30 is God's engine.
