I got a 1990 325i and when i unlocked it then locked it was stuck locked. I got the drivers side door unlocked but it felt like I was gonna break the key. The other three doors are stuck shut even if I try to open them from the inside! What can I do here? My trunk does unlock with the key.
Doors are stuck locked
Ya, I had this problem over the past little while. My passenger door opens when you turn the key (force it) and then pull the door handle. Drivers side is pooched. Luckly my central locking works through the trunk.
I got a lock rebuild kit from pelicanparts.com and that hopefully will fix the totally wrecked drivers side.
My handles from the inside won't even open the door. They're stuck too.
