Alright here's the deal. Whenever the car is placed in a sudden jerky movement (brake suddenly, let go of clutch soon, etc.) even when moving slowly there is a wierd sound from the back left side of the car. It sounds like something in the trunk like the spare tire or jack is moving around but its not. I jacked up the car and didnt notice anything. It's not my exhaust moving around or a bad bushing. My guess is drivetrain maybe? Any help on this because it's driving me crazy.
i cant figure it out... maybe you can?
alright its the same sound like metal hitting metal. if you open up ur trunk and play around with the jack in the back it sounds like that. it doesnt happen on a smooth ride. the speed doesnt matter. it happens only when the car is placed in a jerky movement such as hard braking or releasing the clutch early. its not a suspension related issue either because i shook the car up and no noise.I go wuaaaaaahh pssssshhhhh!!!!
Originally posted by armeNthats what i was thinking. can somebody take a pic of their GOOD shock mount so i can compare because i cant tell without taking it off. im guessing either that or the joints in the drivetrainThe BMW 318 is back. With a vengeance.
Easy thing to check... jack up the rear end (on jackstands, of course) and check all your differential mounting hardware. The front two bolts are notorious for vibrating loose/out and causing this exact symptom, shortly followed by strange rubbing/grinding noises during engine braking.
I think I've got the exact same problem as you.
Get underneath your car and check the half-shafts (CV joints in particular). Even though my CV joint boots look perfect, there was still some slight rotational free-play. This causes a good "clunking" noise whenever you subject the driveline to jerky motion, like you described.
Good luck.
I had his same problem, I drove his car today, you best replicate the problem when you put it in 1st or 2nd gear and let go of the gas and push it again in to jerk the car around, its kind of a creaking sound, can't really explain it, could it be possible that the right shock mount could be fucked and somehow transferring the sound to the left because it really sounds like its coming from the left and he changed his left shock mount, what about gaskets? If could just be the gasket for the shock mount and that should just be like a few cents huh?
