1991 318is Fuel Pump
  • PrinceE30
    • 282
    My Eta's both have the dual fuel pumps (one inside the tank, one outside the tank). I was under the assumption that the 318is only has a single in-tank fuel pump.
    Bavauto has a single fuel pump inside the tank (looks exactly like what I have) for sale.
    http://www.realoem.com has a single outside the tank fuel pump (like my Eta's have).
    I just want to make sure i'm getting the proper info here and getting the right parts. Thanks!
    -Prince
    Randall Prince
    http://www.rp1.us/ Used Cars
  • AdamF 88iS
    • 2051
    You have a single in tank pump.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • arsevader
      • May 2005
      • 1025
      You have to ignore the diagrams in the ETK and realoem. You need to look at the list rather than the picture.
      http://www.realoem.com/bmw/showparts...g=16&fg=05
      James
      • AdamF 88iS
        • 2051
        James
        Yea, numbers 9-14 in that diagram is the whole assembaly you have.
        Adam Fogg- '88 M3
        • fabianyee
          • 195
          Is item number 11 (fuel gauge) included when buying the fuel pump+bracket?
          What I did was to change the fuel pump only from another make when mine went south a couple months back.
          BMWClub Malaysia
          www.bmwclubmalaysia.com
          • arsevader
            • May 2005
            • 1025
            No the sending unit is not included with the pump. You just remove the old one from the pump and install it in the new pump.
            James
