overheating
    overheating
    so when the car is still and idling i have coolant coming out of my overflow hose, does that mean my thermostat isnt opening up. but when i pressed the gas it tends to open up and cool the car . I just want more input if thats the problem.
    Running hot at idle could be a bad thermostat, but it could also be a bad fan clutch.
      i was leaning toward bad fun clutch could also be the water pump going out if you have the m20 some of those water pumps had plastic impellers blast your heater on high with idling lol
      Originally posted by bmwm42
      PNW vulture pm me for parts
      Strategic nw e30 command
        i turn the heat on and the car gets hotter; the fan is spinning though
          i dnt let it get to that point of hot but temperature climbs up there.
            the fan will always spin try and see if you can stop it with a rolled up news paper
              alrightt
                also check the hose that goes from the thermo outlet to the radiator i can almost put money on it that its going to be cold indicting a shitty thermo
                  actually it was cold when i was running the car. ordering my thermostat today and installing it will let you know if things are good.
                    You have a t-stat that is stuck closed imho. Did you bleed the system? Check the hose to t-stat and from. If from is cold 100% tstat is faulty.
                    Founder @ Maintenr. Take control of your vehicle maintenance.
                      yea it was thew thermostat
                        Wrong tstat temp?
                        ส็็็็็็็็็็็็็็็็็็็็็็็็็
                        I need you to exfoliate my ballsack
                        Build Thread?
                          yea soo its still warmsss up there to almost 3/4 hot at idle but no coolant out the overflow now. im guessing its the water pump now x_x but imma just do a complete overhaul on the engine before the summer. Can it also be that i have to bleed the system???
