Driveshalf trouble
  • warren g
    • Jun 2010
    • 27
    Driveshalf trouble
    Do you have to buy a new driveshalf when it goes bad or you just buy new cross because the front of is ok but the back has a vibration after 60km help.
  • Aleksey
    • Feb 2011
    • 336
    I'm pretty sure you can balance the drive shaft or get one from the junk yard for cheap. Are you differential mounts okay?
    Founder @ Maintenr. Take control of your vehicle maintenance.
      Vibration from the drive shaft is almost always caused by binding u-joints. The rear u-joints are usually the firt to go. The solution is to get a new or rebuilt drive shaft. I like those provided by Drive Line Services of Portland.
      • warren g
        • Jun 2010
        • 27
        Thanks jleve i guest new it is.
        • HippyEarly
          • Jan 2010
          • 320
          I just swapped out my center bearing on my shaft. The rubber had worn down and bearing had free movement. Finished that so i could take a 700 miles round trip and my d-line vibs are gone. Car drives great.
          Im not saying don't do the whole drive shaft but a csb worked for me, for now. As every one suggests from my searches to replace the guibo shaft csb and diff bushings at the same time because they all act togeather. $$$$ though :(
          Been with me for 16 years...
          Wish i had more time to play with her
          • warren g
            • Jun 2010
            • 27
            Got one today guy said A1 condition thanks everyone 4 the help.
            Live Long E30!
