2 heat related questions.
  • BS87
    • 1606
    1st. My tranny seems to put out an inordinate amount of heat. So much so that if i grab the bottom of the shift lever through the boot (near the ball), the lever is almost hot to the touch. Since i have no ashtray, i can reach under the console and touch the chassis metal, which is significantly hotter. Is this normal? If not, what the hell could be generating so much heat in the tunnel?
    2nd. My car has always run at or slighly above (1mm) the 1/4 mark on the guage. Today i noticed that it was above 1/2. This was in stop and go traffic, and at a standstill. When i started to get into open roads and cruise, it quickly went back down to 1/4. Whenever i came to a stop light, it would start to rise to 1/2 again, then when moving it would sink to 1/4. This is a dying fan/fan clutch/water pump, right? If not, what else is going wrong?
  • James Crivellone
    Head Janitor
    • 6305
    Number 2 is a bad fan clutch
    • AdamF 88iS
      • 2051
      #1, some heat is normal. Check the oil in there and make sure its full and not a million years old. Thats about all you can do for it.
      #2, fan clutch.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • BahnE30
        • 1050
        hmmm, if it helps any i have fresh MTL and my gets a little warm after HARD drivign, around town not warm at all..
        • nickmp0wer
          • 1427
          you car should be at the half mark all the time
          • hamann318is
            • 3382
            That's true if he has a M42. The M20s run colder.
            The BMW 318 is back. With a vengeance.
            • arsevader
              • May 2005
              • 1025
              All 3 of my M20s have run just below the half way point.
              James
              • hamann318is
                • 3382
                James
                Yeah, the M20 should fall below 1/2. I'm trying to say that the M42 stays at 1/2.
                • BS87
                  • 1606
                  Thanks. Also, tranny is full with brand new Redline MTL, however i'll double check next time it's in the air (soon).
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    I just ordered a new fan clutch tonight via eap4parts.com It was $64 shipped to Indiana from Oregon. I have the same heat problem (number 2). So if you wanna wait a week to see what happens when I swap my fan clutch I will let ya know what happens with it :)
                    Will
                    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                    Welcome e30 (brilliantrot '90 325is) 12/23/06
                    DaveCN = Old Man
                    My signature picture was taken by ME! Not by anyone else!
                    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                    • kowalski
                      • Jan 2005
                      • 1791
                      iv gfot an M42 and i stay at just above 1/4.
                      • BS87
                        • 1606
                        Well, i don't think the fan clutch died on it's own. I looked today and the fan is actually stuck. It hit the bottom lip of the radiator, and stuck there. Two blades are snipped off at the corners (think chamfered), so i'm guessing the PO had it atleast hitting before. Is there any reason why the fan would shift so much as to hit the radiator bottom? The motor mounts are brand new, less than 3 weeks.
                        • hamann318is
                          • 3382
                          How hot is your t-stat?
                          • nickmp0wer
                            • 1427
                            its probably stuck open, replacing mine fixed that.
                            • Tangent
                              • Mar 2004
                              • 476
                              My M20 runs at the halfway mark in heavy traffic in hot weather and/or when the A/C is running on a hot day. Otherwise runs just a couple of needle-widths above the lower normal mark.
