I recently changed my timing belt and other belts, water pump, thermostat, fuel filter, FPR and when i start the car the temp gauge starts tripping out. I noticed though when I press the gas it goes up to where it supposed to be and stays still but when I let go of the gas it starts fluctuating between where it is supposed to be and the lowest position. Any suggestions of what it might be? Thank you all for your help, Jai
Temperature Gauge Flippin' Out
Tags: None
Does it go up and down when you roll up the windows and turn headlights on?
If so mostly likely its a Bad ground on motor side. I think its located on and oil pan bolt... Maybe dirty, clean up and should be ok or replace and mount somewhere else.
My cousin had this problem and that fixed it.
325i LSDed, 17x8.5 et15 BBS CH's, Bilstein Group N SuspensionComment
corrected
Hey thanks for the pointers...
For some reason it corrected itself, but now the mileage does not work=). If it's not one thing it's the other. GRrrrr....welcome to E30 world huh=)-1975 BMW 2002
-1989 BMW 325isComment
