starts and shuts off 90 325iS moto 1.1
  • dirtygerman
    • May 2004
    • 529
    When the car is cold (hasn't been played with all night).. I'll go out and it will start to around 550-650rpm not sure.. for about a second and shut off.. after that it will just keep cranking... until i let it sit again.. any suggestions?
    Im going to check the following stuff tomorrow
    Fuel reaching rail, Spark, Grounds, if the injetors are getting signal.. the relay for the fuel pump the main fuel, pressure regulator.. air flow sensor, fuel pump, ct sensor, pulse sender, throttle switch, leaks, ecu stuff, timing.. i know im just going to run through stuff, but maybe somebody can point me in some kinda other direction.. thanks! ;)
    '92 Golf VR6
    '91 325i
    '95 cabrio
    '94 jetta vr6
