vacuum leak
  • NC325iC
    • Mar 2004
    • 6565
    vacuum leak
    is there a fault code 1222? or did i read it wrong
  • arsevader
    • May 2005
    • 1025
    Lambda Control 1
    O2 sensor or (more likely) a vacum leak.
    James
    • erik325i
      • Jan 2005
      • 3567
      Just for reference, here is a list of the fault codes:
      • NC325iC
        • Mar 2004
        • 6565
        how might one track down a vacuum leak?
        also is there a way to adjust the idle on a 1.3?
        524 is 1.3 right?
        • NC325iC
          • Mar 2004
          • 6565
          vacuum leak
          someone has to know
          • AdamF 88iS
            • 2051
            No, you can't adjust the idle.
            To find the leak get a can of brake cleaner and spray it around various places on the intake. When the leak sucks the stuff in the idle will change. I will say right now to check the rubber boot from the AFM to the throttle for cracks, check all the pressed in fittings on the side of the throttle for the brake booster and idle valve, and check the breather hose from the valvecover. Those are common vac leaks on these cars.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • jht3
              • 288
              please don't use brake cleaner. go get real throttle body/carb cleaner and spray it sparingly on common places like where hte throttle body connects to the head and other vacuum ports.
              James
              '88 M3
              • AdamF 88iS
                • 2051
                What difference does it make? As long as you're not drenching the motor with it you'll get the same effect from either one.
                Adam Fogg- '88 M3
                • NC325iC
                  • Mar 2004
                  • 6565
                  so im guessing i should let it warm up first, i dont have a cold idle(i dont think , may have adjusted after last time) what could cause this?
                  • kowalski
                    • Jan 2005
                    • 1791
                    brake cleaner is much more corosive then cab cleaner. it will eat paint and such, what you could use is ether, which would make your idle pick up when it got it, and its not corrosive.
                    • arsevader
                      • May 2005
                      • 1025
                      or propane or a number of things. I think you are confusing brake cleaner with brkae fluid. ;)
                      James
                      • jht3
                        • 288
                        well in my case of leaking throttle body gaskets, the space would seal up better as the engine heated (think thermal expansion). i shot of tb cleaner right by the gasket and the engine would sputter. when i took the plenum off, i found a hose that was cracking.
                        go to the parts store and buy a can of tb cleaner or starting fluid. the first will make your engine bog down, the other will rev it up. both are safe for your engine health in moderation.
                        James
                        '88 M3
                        • kowalski
                          • Jan 2005
                          • 1791
                          James
                          ahh yes:) hahaha oops.... i use propane cause its not messy.
