Aux fan removal/replacement
  • dark_islight
    • Jun 2005
    • 41
    Can you remove the aux fan without removing the radiator and condenser?
    dark_islight
    _____________________________________________
  • Jordan
    • 12916
    Yes, but you have to take the whole front end of the car off.
    https://mtechniqueabs.com/
    • dark_islight
      • Jun 2005
      • 41
      How much of the front of the car?
      Grilles, bumper and what else?
      I have a Bentley on order but I won't see it for at least 2 weeks.
      dark_islight
      • DEV0 E30
        • Oct 2004
        • 8904
        Taking out the radiator isn't hard at all, personally I haven't taken off the condensor but that wouldn't be hard either I don't think.
        Basically he's saying it would be more work.
        • dark_islight
          • Jun 2005
          • 41
          I don't want to remove the condenser because the a/c is charged. I would prefer to do it from the front if possible.
          I have 2 cars and time isn't the issue. I just was inquiring as to how many parts need to come off to access the fan and pull it.
          dark_islight
          • Jordan
            • 12916
            You need to make your car look like this.
            • dark_islight
              • Jun 2005
              • 41
              Perfect, this is what I was looking for.
              dark_islight
              • arsevader
                • May 2005
                • 1025
                You don't actually have to dissconnect the A/C lines. You just need to move the condenser out of the way.
                Jmaes
                • dark_islight
                  • Jun 2005
                  • 41
                  Justin,
                  I did as you said and it worked out fine. Just took 8 hours because I had some other issues to deal with while the front end was off.
                  Thanks for the info. :D
                  dark_islight
