320i ignition module wiring help needed!
  • pizzaboy69
    • 11
    hey guys i really need help on this one. i had to remove the connector coz it was cracked and would wiggle while i drive which would cause the engine to die so i had to cut off the connector and solder the wires straight to the pins. now the problem is the car wont start anymore! it would start before i took out the connector. im posting a pic of what i did. can anybody tell me if i got the pinning and the wire colours correctly? i wrote them down before i cut it up but i just need someone to confirm if i put it the correct wire to its pin.
