Destroying a water pump?
  • E30godz
    • 1524
    can you destroy a waterpump by running low on coolant for an extended period of time?
  • Jordan
    • 12916
    No.
    https://mtechniqueabs.com/
    • AdamF 88iS
      • 2051
      Re: Destroying a water pump?
      Only if it's pretty much totally empty on coolant. The antifreeze has a pinch of silicon in it that helps to lube the shaft.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • permit
        • Mar 2005
        • 3363
        Originally posted by AdamF 88iS
        lube the shaft.
        :giggle:
        • AdamF 88iS
          • 2051
          lube the shaft.
          :giggle:
          I was hoping somebody would catch that.
          Adam Fogg- '88 M3
          • Jordan
            • 12916
            But with the coolant so low that the water pump isnt even slightly submerged there is basicly no coolant in the system, certainly not a drop in the head.
            You would warp the head and crack the block long before the water pump packed up and went home.
            • AdamF 88iS
              • 2051
              Yea.
              Incedentally, this is also why you shouldn't run straight water in the cooling system.
              Adam Fogg- '88 M3
