E30 runs RICH AS HELL
  • pharow
    • Jul 2010
    • 1021
    I had the same problem. It was a clogged return line in the gas tank. I had to replace the tank.
    Just check your return lines.
    '02 Outback wagon
    '87 325is 5sp
    '93 Kawasaki ZR1100
    • DaveSmed
      • Apr 2007
      • 1406
      Grab a fuel pressure tester, tee it into the feed line.
      Next, remove the bolts that hold the fuel rail into the intake, and wiggle the rail/injectors out and lay them on the valve cover.
      Remove and jumper the fuel pump relay to turn on the pump.
      Now, make sure every injector is dry and post up your gauge reading.
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
      • lolcantturn
        • 4588
        Oh my..I don't want to have to replace my tank ...
        Will do, just gotta get hold of a fuel pressure gauge now. What could change the pressure? My FPR is new..when I disconnect the fuel return from the FPR it's basically dry
        Originally posted by TSI
        OEM+
        • StereoInstaller1
          GAS
          • 22679
          Hmmm..dry? No way should that return line be dry.
          Check the vacuum source on the FPR.
          Closing SOON!
          Thanks for 10 years of fun!
          • lolcantturn
            • 4588
            Will do. I know the vac line is good, the actual line itself is in good condition but not sure if it's vacuuming or not. I know that if I disconnect the fuel return line from the FPR and jump the fuel pump It shoots out gas at the rate Bentley recommends
            OEM+
            • b*saint
              • 3794
              How rich does hell actually run? Do they have a dirty injector or something?
              Ma che cazzo state dicendo? :|
              • lolcantturn
                • 4588
                OEM+
                • lolcantturn
                  • 4588
                  well I am stumped ladies and gentlemen.
                  FPR return line looks good, I turned on the car without the line attached to the FPR and it was gushing out adequately. Vaccum line to it is..vacuuming. No exhaust leaks. all spark plugs spark. Oxygen sensor is receiving signal, main relay is receiving signal, coolant temp sensor is recieving signal, coolant temp sender is too. Switched out DME's same problem.
                  One thing I noticed is that my MPG's go up (according to the "all accurate OBC) from 10.1MPG to 12.7MPG max when im NOT idling.
                  fuckkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkkkkkk
                  OEM+
                  • Blackangusinc
                    • Jul 2010
                    • 244
                    It was gushing out of the fpr right? Meaning the return line could still be plugged.
                    971-295-7077
                    91' 318i
                    • Gruelius
                      • Oct 2009
                      • 298
                      try breathing through it if you cbfed buying a fuel pressure tester.
                      did you funk with the afm?
                      RIP 84 323i coupe 5spd w/ 14psi
                      89' 318i
                      • lennon
                        • Jun 2008
                        • 1416
                        +1
                        You need to put a pressure gauge in and check the pressure at the rail. A clogged return line will cause the pressure to be very high, thus the engine will run very rich if at all. I just had to replace a tank in an e30 because of this. The late model tanks return line runs into the tank and across the inside. These can get clogged, but usually from sitting and tank rusting and all. I would be a little surprised if your return line got clogged out of nowhere. However, since you're troubleshooting a fuel problem, you need to test the fuel pressure...
                        edit: BTW autozone or whoever your local chain store is should have fuel pressure gauge sets in their tools you can "borrow". Just put down the deposit and bring it back when you want.
                        • lolcantturn
                          • 4588
                          Originally posted by lennon
                          +1
                          Right-o, I'll go borrow a fuel pressure gauge today. I will be very pissed if I have to replace my gas tank ugh. I don't see how it could clog out of no where, my car never sits lol.
                          OEM+
                          • lennon
                            • Jun 2008
                            • 1416
                            yeah, it's probably not the return line out of nowhere. just gotta see those fuel pressure numbers!
                            • StereoInstaller1
                              GAS
                              • 22679
                              Yeah, fuel pressure and residual fuel pressure are both critical.
                              Closing SOON!
                              • Bene
                                • Feb 2011
                                • 358
                                how old/dirty are your plugs? or your ignition system in general
                                my car ran like ass, and my exhaust looked like an old diesel in the morning. I changed the plugs and now it runs incredibly smooth.
