I've tried jumping the green/black wire with the black with no luck, checked fuse 17, 18, 19 and I believe 3 and all fuses are good. Where would be my next step to diagnose the problem?
Aux Fan not jumping
you will see either a silver color bar with two wires going into it held on by two screws. This is your resister. Or it could be a finned black bar with the same two wires. The screws are usually difficult to remove especially with the black resistor. I would turn the screw clockwise first a bit just to break any corrosion and then remove the screws holding the resistor in -if this is the issue you are having with your problem. :-)sigpic
