So i'm getting very anoyed with not having my low beams working. The low beam check light hasn't come on at all since they stopped working. I can get the bulbs to light up and I've replaced the relays. I performed the test indicated in the Bentley manual and both the High beam and Low beam relay sockets failed the terminal 30 test for power. (Ignition OFF, test to ground, should have battery voltage, both had none) I also have a short that is on a circut without a fuse. There is a constant drain on the battery but no blown fuses and all accesories off. If I remove fuse 17 the drain reduces by .2 volts but since that fuse handles a ton of stuff that is hard to pin down.
Anyone have any experience chasing down similar electrical problems? Anyone have any idea what I should do next? The manual doesn't really help much after i've done the test as to what is means and other such help...
Thanks
Thanks
