posted this on some other forums and im just trying to get an answer as soon as possible
OK so i just got done replacing the clutch in our lola and i take it for a drive and all is well. Then my dad takes it and the clutch starts slipping again. well i take a look at it and i can see that the clutch arm is not all the way back. I freaked out because i thought i messed up something inside and was going to have to take off the transaxle again. I unbolted the slave cylinder and the arm punched back to the normal posistion so that means the problem is in the hydrolics. With the previous setup the slave would go back very slowly but i dont know if that was because of the slave or the very worn and old pressure plate.
I undid the bleed screw while applying pressure to the slave and fluid came out and the slave retuned to the normal posisition. So some how some extra fluid got in there. It seems like the slave probably didnt return all the way for some reason while the pedal did then when the pedal was pushed again extra fluid was put in but it could be something else.
What do you guys think the problem could be and what should i repalce?
thank you very much for your help, hopfully i will be able to get what i need ordered tonight
