Rear window sticks on way down. Motor or guides?
  • evilnickwong
    • Aug 2007
    • 302
    My rear power window on one side hasn't been working for some time. I took it apart the other day to disassemble to motor and found the center shaft was rather corroded and rough. After smoothing it down and cleaning and lubing the rest of the bits in the motor, the regulator runs alright up and down on its own. (Just testing it connected to power on it's own)
    But once I put it in and connect it up to the glass, it sticks on the way down. If I push down on the window to help it along, it struggles down. Oddly, going up which I thought would be harder works fine.
    Is this just a weak motor, or are the rubber guides which are quite old creating too much resistance?
  • bmwm42
    • 6300
    The regulator
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • evilnickwong
      • Aug 2007
      • 302
      Regulator = the whole bit with the cable running along the 2 wheels at the top and bottom of the frame?
      What about it can I try to fix?
      • !kid
        • 1362
        spray a good amount of WD40 on the cable thing if the issue goes away I would suggest taking the hole regulator out and giving it a good cleaning and re grease it.
        :borg:
        • evilnickwong
          • Aug 2007
          • 302
          I've done this already, cleaned all the old thick grease off and layed new grease on.
          • !kid
            • 1362
            okay. what about taking the motor from another window and installing it on the bad side to rule out if its the motor or regulator.
            :borg:
            • evilnickwong
              • Aug 2007
              • 302
              This brings up an interesting point. My car is a 1991 sedan.
              Are the motors interchangeable from left to right? I would imagine they're not, but I dunno. I think from front to back definitely won't work since the front one is a sealed unit (at least for the innards, I know the commutator section can be removed) as compared to the rear one which can be completely taken apart.
              Also, I understand that motors can obviously get weak with age.
              But how are regulators the possible fault? They seem like just a simple cable/pulley system and if nothing is broken and it all moves properly, I don't see how it can be contributing to a stuck window.
              Thanks for the input guys. :)
              • bmwm42
                • 6300
                If the pulley are damaged teeth missing etc the motor can only roll the window down so far
                • evilnickwong
                  • Aug 2007
                  • 302
                  It goes all the way up from bottom just fine.
                  From the top it goes down for only abit, then I have to help it by pushing the window down.
                  By the way, something else I did notice. Here is a photo of my left side rear motor + regulator (which DOES work) when I disassembled it for cleaning.
                  One thing I noticed when I was doing the same for the right side which doesn't work, is that the part circled in red, I couldn't remove it from the motor housing (blue part). On this left side that's pictured, it came out real easy, but on the side that doesn't work, it won't come out at all. I tugged at it all I could, but it wouldn't budge. Dunno if this means anything.
                  • !kid
                    • 1362
                    what car is this for?
                    :borg:
                    • evilnickwong
                      • Aug 2007
                      • 302
                      It's a 1991 318i M40B18 sedan.
                      • Ceeker
                        • Sep 2009
                        • 2821
                        Your motor is tired. replace the window motor. I have rebuilt a quite a few of these in the past. if it brings the window down easy and struggles going up. its the motor. You can use the other side but you will need to build them back up. the part circled in red are the brushes. You may see some flat spots of wear on it. this is where it hangs up while spinning to get the window to wind back up. the resistance wears them down; since less material is present makes for more resistance on the magnet; if it misses while spinning the motor stops all together and sometimes you have to bang the door panel to get it going again. I had problems with all 4 doors on my IX one time. the reason it isn't coming out because it is seized with corrosion. I also encountered the same thing as you.
                        • evilnickwong
                          • Aug 2007
                          • 302
                          Mine's the opposite, it goes up easy, struggles going down. :D
                          You're right about the brushes bit though. The shiny aluminum part (the fat part with horizontal lines on it), some parts are flattened down.
                          The copper part where the carbon brushes make contact is fine though.
                          If it's corrosion, any idea how I can get it out? Because I have a spare brush from a front motor that works, so if I can get this out, I can swap just that bit in and see if it works.
                          There is a slotted screw under the brush shaft, but it doesn't seem like I can remove it easily. It's real tight.
                          • evilnickwong
                            • Aug 2007
                            • 302
                            Bump! Would really like to know how to free the brush part from the motor housing so I can replace it with another one and see.
                            • Heysüß
                              • 911
                              I also want to know if the 4 door e30s rear window motors are interchangeable from side to side. Mine is stock down and I'm pretty sure it's not the regulator I'm pretty sure the motor is shot.
                              09/1989 325i 4 Door
                              +M30 Swap
                              +Z3 Steering Rack
