Steering wheel locked
  • royalflush313
    • Mar 2004
    • 2070
    For some reason, I can't turn the car on, because the key will not turn. And steering wheel is locked up and I cannot wiggle it to turn the ignition.... any suggestions?
    ~ Go Canucks Go! ~
  • nickmp0wer
    • 1427
    jack the front of the car up? you should be able to wiggle it while tunring the key
    • royalflush313
      • Mar 2004
      • 2070
      any other ideas?
      ~ Go Canucks Go! ~
      • Bimmerfanatik
        • May 2004
        • 5349
        Use one arm to move the wheel back and forth, and the other to jiggle the key. Patience - it'll work.
        • nickmp0wer
          • 1427
          wait, so you jacked the car up and couldnt do it?
            • 37828
            Bust the ignition
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • royalflush313
              • Mar 2004
              • 2070
              no, but I don't see how that would help....
              And Beemerfanatik, wiggling the steering wheel is not working. I tried for quite a while with no luck. It's weird because I've never had any problems starting the car up, and one day, I park the car, go back to turn the car back on, and the steering wheel is locked up & ignition won't turn. :?
              ~ Go Canucks Go! ~
              • Bimmerfanatik
                • May 2004
                • 5349
                Jacking the car up would free the front wheels - therefore taking any resistance off the steering rack. If the jiggle key/wheel method isn't working - that's the next thing I'd do. Worth a try - you lose what, 5 minutes if it doesn't work?
                • davidl
                  • Mar 2006
                  • 4
                  Did you ever find a solution to this problem?
                  I currently am going through the same problem. I already tried both methods listed
                  • arsevader
                    • May 2005
                    • 1025
                    No he never found an answer and the car had to be totalled.
                    Try holding the wheel as far as you can one way while jiggling the key.
                    • blueapplesoda
                      • Dec 2005
                      • 1904
                      have u had ure key remade? my friend had the same problem...we just muscled it hoping the key wouldnt break inside the column cylinder, and it just clicked. They key he had was remade at the dealer.
                      • davidl
                        • Mar 2006
                        • 4
                        I have tried both my regular and my spare key, both to no avail.
