FPR- cant find one for my car
  • moose_7
    • 54
    I recently decided to replace my Fuel Pump, FPR, and Filter. Everywhere autoparts store i go to cant seem to get the right FPR, they all order something that doesnt work for my car. I have an 87 325e with no fuel system mods of any sort, it is the original part however i cant get one. My FPR has two ports for fuel lines to connect to it, it held on the car by a stud on the side and a nut. The FPR they order has three connections for fuel lines and they are all different size connections and it has a bracket that two bolts would go through to attach it to the car. ANY HELP IS APPRECTIATED, AND PART NUMBERS.
  • rs4pro3
    • 5808
    Sounds like the one's they are ordering are correct and your old one is wrong, FYI the fitting on the bottom pressed into the fuel rail, the other Larger fitting is the return to the tank, and the small fitting is for a vacume line.
    http://www.realoem.com/bmw/showparts...g=13&fg=15
    #6 on that diagram is what you need.
    85 325e 2.7 ITB'd stroker
