My 1991 sedan's left rear window will not go down. (Realized I hit LF in the title, sorry.)
I swapped both the front and rear switches out for known good ones (from the same car) and nothing. I got a spare window motor & regulator, expecting the worst. I decided to test the new motor outside of the car. Hook it up, hit the up button, it goes up, hit the down button, nothing. (This is using the front switches by the shifter.) I then tried the rear switch on the door. Nothing. No up, no down.
I swapped the switches again to see if that made a difference, nope. I'm thinking I have some ugly wiring problem now. All the switches light up, no problem. It's just the rear doesn't work at all, and the front switch, for the LR window only goes up.
Gimme some suggestions, where should I look first? What should I test? I'm eyeballing the ETM right now, but my netbook screen is oh so small....
