im trying to take out the selector rod out of the shifter joint to put in a new one but it wont come out, i have the driveshaft and exhaust on and really dont wanna take it off just to change this, is there some sort of trick that im missing?
selector rod doesnt come out of the shifter joint
you have to rotate the white nylon cup 90 degrees, I forget which way. you're supposed to use a tool from below but I tried using one or two screw drivers from the top. Mine would spin for like 15 degrees and bind. I ended up having to break the tabs on the side of the white nylon cup to get it to come out. Good luck, and invest in a bentley manual, it tells you how to do all of this.318is -gone-
Is the "cylinder with a larger diameter" really thin (like a washer)? I think that is just the c-clip. When I replaced mine, the rear one popped off very easily, but the front one looked like there was no clip on it. Just a c-shapped washer that is clipped onto the notch on the end of the selector rod. You just have to pry/destroy that clip to get it off. When you replace it, you can put on a normal clip to make things easier.Originally posted by zandiThe shifter rod apparently has a notch and then an cylinder with a larger diameter and thats why its not coming out, WTF
Hope that helped.
Hey Erik, thanks for the response, really appreciate it, I already had one of those older clips on and destroyed it and put a newer one on, but I remove that when I try to remove the shifter rod. I just don't understand the other side comes out like a snap but this other side I break my balls and pull to get it out and it just won't come out, theres no circlips on it or nothing.Comment
What is this cylinder you are talking about? Is it skinny, like a washer that is stuck in the notch at the end of the selector rod?Originally posted by zandiThe shifter rod apparently has a notch and then an cylinder with a larger diameter and thats why its not coming out, WTF
My guess is, like I said earlier, that it is just the c-clip that lost the clip part of it. Now there is just a c-shaped washer holding on to the notch on the selector rod. You have to either use two screwdrivers/pliers to get if off.
If it is something different than what I am thinking, you should take some pics of the problem, so we can get a better idea.
That sucks. I don't really know what to tell you now, besides try spraying some lube on the end, so that it can slide out easier. It sounds like it is just binding on something. The selector rod should not be larger at the end, so it should just slide out now. Good luck
