Has anyone switched their front brakes from Girling to Ate?
I need to replace the front calipers on my track rat car and I'm wondering if I should try to switch to the Ate's and upgrade the guides with a bushing kit to eliminate some of the caliper twisting. The kit is apparently is only for the Ate guides. The Girlings that are on there now have LOTS of slop/twist on the guide pins and the pads are unevenly worn from twisting.
Would the Ate's with the bushing kit be a noticable improvement? If so, where is the best place to get the ATE caliper carrier, and is that the only other part I would need? Are there other differences?
Thanks in advance.
Thanks in advance.
