Differential help.
  • jdvorwe
    • Apr 2011
    • 366
    Differential help.
    Working on replacing the differential on my 87 325e. Soaked everything in PB last night and got all the bolts off today. It is disconnected from the axles and the driveshaft and the rubber mount. But, the 4 mounting bolts are proving to be pretty hard for me to get to and work with. Any advice on getting these 4 bolts off? Anything would be appreciated.
    These are the bolts that I am talking about. Just in case I wasn't clear.
    Originally posted by trackjunkie21
    when there is a choice between an e36 and another car, you choose the other car.
    The only easy way to get the differential off/on the subframe is to drop the subframe.
    • b*saint
      • 3794
      Those bolts were cake for me. This is what you need to do. (I invented this procedure.) You need to use a bolt and nut as a link between a wrench and ratchet. You understand? I have a picture of it I can post.
      Ma che cazzo state dicendo? :|
      • FredK
        • 14761
        I use a hammer on a combination wrench to break them free.
        • jdvorwe
          • Apr 2011
          • 366
          That is what we were thinking about doing tomorrow (today, or whatever that is now)
          a picture would be nice. not really picturing it.
          This is what we tried already. Did not want to budge.
          Thanks for all of the help/suggestions guys.
          • jdvorwe
            • Apr 2011
            • 366
            Actually, now that I am thinking about it more I think I can picture this. Not enough room to get a ratchet on the top ones, so this method still requires us to drop the subframe, yes?
            • b*saint
              • 3794
              No the other way around. Give me like a half hour I will get a picture for you.
              • b*saint
                • 3794
                What you will need:
                Your "link"
                Assembled.
                You can use a combo wrench but its just a little clumsy until you put some pressure on the whole assembly. This worked great around the exhaust pipe because you can position the ratchet any way you want to clear around things. I think the forward driver side I had to use a smaller ratchet.
                • bimmerteck
                  • 762
                  or but the closed end of a combination wrench on the bolt and then plant a prybar against the body and use the prybar as leverage against the wrench to break them loose.
                  • b*saint
                    • 3794
                    That works too except the pry bar slipped out once for me.
                    • jdvorwe
                      • Apr 2011
                      • 366
                      Thanks for the help guys. We ended up taking the sway bar off and finagled a torque wrench up there. Just needed that little bit of extra room. Got the diff out today.
