Involvement of Diff Swap
  • rwh11385
    lance_entities
    • 18403
    I'm probably looking forward to swapping out my differential sometime,
    but also, my guibo should be replaced in the coming year or so.....
    So my question is...... how much is involved with the diff swap, is the removal of parts, say exhaust required. If so i'll do both at the same time......
    Also, what is best for a daily driver/occasional autocrosser 3.93? or 4.10? I spend little time on the highway, mostly in the city.....and i'd like the extra scoot. What you guys say?
  • Ryan Stewart
    I Love Miatas
    • 8978
    none of those are really bad. If you are gonna drop the whole exhaust to do the guibo you will need some good extensions. I used those ones that are tapered on the end so they can flex a bit. Its kindof a PITA but if you are patient it will work. Good idea to get new copper fasteners.
    The driveshaft is simple, the bolts on the end and the bracket that holds the center support bearing. As long as you are dropping it a full short shift kit, replacing the arms and bushings, would be nice.
    The diff isnt techincally hard, you can do it without dropping the subframe. The hard part is breaking loose the bolts holding it to the subframe, those are on top and you cant get a socket in there, you can either use a cheater bar or have an insanely built friend break em loose with a simple wrench.
    If you can spare the cash you can put a M coupe diff there too.
    Im now E30less.
    • AndrewBird
      The Mad Scientist
      • 11898
      For the two bolts on the top, you can use a slightly larger wrench as a cheater bar. Make sure when you remove the bolts holding the drive shafts to the diff, you clean out the holes in the bolts first so the hex wrench will fit into them and not strip them. This can be hard to do...
      Andrew
      • rwh11385
        lance_entities
        • 18403
        thanks you two, but my main question is: is there a benefit of saving time in doing both at the same time?
        • AndrewBird
          The Mad Scientist
          • 11898
          Definitely a benefit in saving time because you don't have to drop the exhaust down twice along with all the heat shields.
          Andrew
          • diegom6
            • 4447
            I had the stock diff 3.73 LSD, and then swapped with a 3.91 LSD, I din't notice much difference , but the revs went firmer up to the limit...the swapp is not big deal!
            Just dissamble the nuts of the shafts, then the nuts of the top or over the diff, they are three I think...the main shaft, some jacks...well, I not remember well....the proccess
            Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
            • Ryan Stewart
              I Love Miatas
              • 8978
              yeah, and like I said, if you are going the guibo might as well go ahead and drop the shaft while you are in there and replace those worn shifter bushigns with a nice SSK. :)
              Im now E30less.
              • rwh11385
                lance_entities
                • 18403
                haha, good one......
                also thanks man
                i'll be sure to save up and do both at the same time!
                • Bill 84 318i
                  • 1600
                  Andrew
                  Huh? You don't have to drop the exhaust, heat shields, or driveshaft to do the differential.
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Oops. Not thinking. You do have to remove the bolts that connect the drifshaft to the diff. Those might be hard to get to without dropping the exhaust. Would make it a lot easier to do it when you do the guibo.
                    Andrew
                    • Bill 84 318i
                      • 1600
                      Andrew
                      Nah, the exhaust doesn't really get in the way at all.
                      • Uber E30
                        • 1409
                        So, im taking my LSD out right now, have everything unbolted. My problem is that when i lower the diff it doesnt break free of the driveshaft bolts. I have already removed the nuts(obviously) I have tried rocking the diff around and pulling the jack forward as much as it allows. I'm not able to play with it much as i cant lower it enough to get the bushing free. Any suggestions?
                        -Alex
                        • E30SPDFRK
                          • 5713
                          Stick a flathead screwdriver in between the driveshaft and the input flange and pry the 2 apart.
                          Byron
                          Leichtbau
                          • PhillyG
                            • 754
                            Not to be a dick, but you have 14k fucking posts here and you don't know this shit?
                            • kronus
                              • Apr 2008
                              • 13032
                              Learn to read and look at post times.
                              cars beep boop
