windshield sprayers clogged?
    i need to get my windshield washers working to pass safety.
    the system works fine for the most part, but the hose splitter just sprays out of what I think are relief holes on both sides.
    anyone know what this is all about?
    Yes I just cleaned up my rear sprayer and it works fantastic. What you need to do is confirm you're getting plenty of flow by unhooking the sprayers and visually checking flow. Should spit out a couple feet at least. Then remove the sprayers and clean them out using a torch tip cleaner. Might be a good time to rinse out your washer fluid reservoir.
    Ma che cazzo state dicendo? :|
      You may need to also replace the splitter as most likely your fluid froze and split it so no pressure getting through!
      The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
        You can replace the splitter with plumbing T's from Home Depot/ Lowes.. They are small and white, costing about $.30
          Take a needle and poke it in the sprayer holes, easiest way to clean them out.
          Originally posted by KingB
          Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
