E30 X20 Pinout
    E30 X20 Pinout
    Does anyone have the X20 pinouts for an 86 BMW E30 handy?
    Working on wiring and could use it.
    Already have the Bentley 1986 BMW 325 Electrical Troubleshooting Manual but was running into issues on identifying them.
    Have a few so far:
    25 Blue Alternator charge
    21 Green Start/Run Wire from Ignition Switch
    20 Black Tachometer
    18 Black/Yellow Start wire from ignition
    13 Green/Purple Power to Fuel Pump
    Go to http://www.diakom.ru/CARS2/index.html select BMW from menu on left. Then select the first Russian phrase on the right.Then select third Russian phrase below that ( says Mitchell next to it). In drop down box select year, next drop down box select model, third drop down box select wiring diagrams.
      86 325e? I have them for an 86 325es.
      What model car's X20 are you splicing into?
        That will work. Looking into a motor swap, would you mind sending me what you have?
