Fuious with Starter
  • Vass325es
    • 252
    Fuious with Starter
    I have been so frustrated with starter. I didnt realized that everything is tight and couldnt allow me to loose the bolt to remove starter. Anyone can instruction me how to do that?
    Thanks. :?
    1987 325es. LSD 3.25 (Stock)
    1984 325e (shell)
    Goal Project:
    5 Lugs Suspension
    1996 M3 S52
    E36 6 Speed
    Rieger/Mtech Body Kits
    Z3 Steering Rack
  • BahnE30
    • 1050
    keep trying it'll come it's a bitch, there's 4-5 bolts if i remember right, 2 on top 2 on bottom plus the bracket at the front. also if you remove air box it makes things easier, but you've probably already got it out of the way....
    • kansas-ix
      • Jan 2004
      • 1600
      one bolt on top one on bottom, yeah take air box, out you should be able to crawl up underneath the car and get a 17 on the front and back and get that bolt loose the one on the top you might need a long extension and another person to hold the bolt from the front while you turn with the extension from the back, shouldn't be too bad, flashlight will probably be needed.
      E30 325ix 62k
      • erik325i
        • Jan 2005
        • 3567
        Just disconnect you battery, then unbolt the wires to the starter. There are two bolts that hold the starter on. One person goes under the car with some extentions and a socket and loosens the bolt, while one person holds onto the nut in the engine bay with another socket wrench.
        It's a pain in the ass the first time you do it, but it's not too hard once you do it a few times.
        • BahnE30
          • 1050
          so wrong on the number of bolts, but maybe an ETA is different. lol fucking thigns.
          • Vass325es
            • 252
            Get out air box? Air box have so many bolts to remove? I dont think so..
            1984 325e (shell)
            Goal Project:
            5 Lugs Suspension
            1996 M3 S52
            E36 6 Speed
            Z3 Steering Rack
            • DarkWing6
              • Apr 2004
              • 7144
              I remember watching Crivellone do this on his car one night. All I really remember is that it was a bitch to do and it took a lot of extensions and wobellies. Just keep trying it from different angles. Sooner or later it has to come out. I believe it took James a few hours. More than he thought it would.
              • Vass325es
                • 252
                few hours sigh.. :x
                1984 325e (shell)
                Goal Project:
                5 Lugs Suspension
                1996 M3 S52
                E36 6 Speed
                Z3 Steering Rack
                • kansas-ix
                  • Jan 2004
                  • 1600
                  buy a 36" Extension and maybe even drop the driveshaft and go in from the top of the tranny that is the "easy" way, its bad but not too bad.
                  E30 325ix 62k
