ok i have stuck everything i could into the 2 rubber hoses in the trunk is there any other way of de clogging them? I mean im tired of getting wet!
Fucking Sunroof drains!!!!
Tags: None
Re: Fucking Sunroof drains!!!!
drift under a semi - voila! No more sunroof drain clogs.Originally posted by e30 gangstaok i have stuck everything i could into the 2 rubber hoses in the trunk is there any other way of de clogging them? I mean im tired of getting wet!
:)Comment
no sir. go from the drains in the sunroof IMO - if you go from the trunk ones, you'll be blowing the stuff back into it.Originally posted by e30 gangstablow up the rubber pipes in the trunk?Comment
you are not a total noob, shut up.Originally posted by e30 gangstaok so where are these drains in the sunroof? Im a total noob.
I can't say where they start - I know there are holes in the front corners of the sunroof opening, but I believe those go straight down through the a pillars to the rockers. But, maybe those holes go to the rear drains as well. I'm going to assume that the rear drain hoses are hooked to somewhere in the rear of the sunroof track/opening.
Let someone who knows for sure tell you though.Comment
dont take off your sunroof, just open it. Look around with a flashlight an you should be able to see the holes at the front and backComment
