timing off any advice?
    Hi I did my timing belt since I just got this car not to long ago. Well ever since car will not turn over. I alingned both cam and crank. One other thing it back fires out of intake side throttle body and once through air filter compartment. Any ideas people? I made sure plug wires back in correct plug. Thanks in advance..
    Backfiries can be caused by timing errors, or a lean condition. If the crank and cam are correctly aligned and the pulug wires are correct, look for intake leaks or a fuel system problem.
