K5-fuse 17 issues
  • scottinAZ
    • Dec 2009
    • 1312
    K5-fuse 17 issues
    Ok, i spent the last 3 hrs with my nose in the ETM, and either Im a dumbass, or im seriously fucked. I have no power from the K5 unloader relay going to fuse 17 for my power windows. What conditions must be met in order for K5 to give me juice to this fuse (only one on the circuit)
    nevermind, im a dipshit. I dont have a starter installed yet, and therefore there is no path to ground for the relay coil.......
    I saved 15% on my Bimmer parts by switching to ...
  • Click
    • 637
    Looks like terminal 86 needs power. Terminal 86 is connected to 15U, which I believe is powered when the key is in either run or start positions.
    ส็็็็็็็็็็็็็็็็็็็็็็็็็
    I need you to exfoliate my ballsack
    Build Thread?
    • scottinAZ
      • Dec 2009
      • 1312
      power to the relay wasnt the issue. I didnt have ground on 87, because my starter is removed. I overlooked the obvious in search of a problem that wasnt there....
